Subject: Re: Goudey lacquer
Goudey lacquer
4/26/24
Jon
Haven't sprayed in a decade, so I'm a little rusty. Everything is from Goudey. I have a color pre cat lacquer (PC 10—6669 and need to apply primer first. Can I use 888 high solids, or does it have to be 889 high solids? If I remember correctly, I can use either one since the only difference is that the first one was designed for nitracellular slacker and the second for pre-cap. I'm pretty sure I could use the NC primer with the pre-cat lacquer, but like I said it's been a while, and I'm not 100% sure. The guy at the store says I could use either one but I have my doubts since it's going to be a real expensive mistake if I'm wrong. Any help would be appreciated. Thanks
6/6/24       #2: Goudey lacquer ...
JM
Took like 8 seconds to go to the Goudey website, look up the TDS, and read that the companion product is 889 High Solids White Primer.
