Subject: Re: Butyl acetate
Butyl acetate
7/4/24
Mark
I have started to use solvent based 2K acrylic urethanes as my preferred primer and paint.
After doing some research, I believe the the thinner used for reduction is mainly butyl acetate. I am able to buy it in drums for significantly less cost than the 5 gallon pails the supplier sells their universal thinner for.
Has anyone else looked into this and switched?
Thanks,
Mark
7/8/24       #2: Butyl acetate ...
mauricio poli
Hello
It is a slow solvent to be used alone
It is ok to mix some butyl acetate on the top coat, when it is hot mainly.
To use the indicated thinner will give you the quality assurance from your supplier.
7/15/24       #3: Butyl acetate ...
Chemmy
Hmm.. That's different than what was required for the Acrylic Urethane I use to use, which required a highly refined pure
Naptha.!! I would have to talk with the chemist at the provider as to why a Butyl Acetate, the mainly used solvent for Nitrocellulose, would be used instead of an Amyl Acetate.???
Please check this out thoroughly before using or adding.!!
7/24/24       #4: Butyl acetate ...
wisno
Website: http://www.wisnofurniturefinishing.com
Yes agree Butyl acetate is the good solvent for coating. NC, acrylic, PU, Vynil csn be thinned with Butyl acetate
