Subject: Re: Anchor Seal Waterbase Wax as a Furniture Finishing Waxfor
8/8/24
Nimal Perera Member
Hello,
Wanted to get an opinion on using Anchor Seal End Grain Sealer Wax as a furniture finishing wax. Has anyone used Anchor Seal water based Wax for this purpose? Or would it be ok to finish furniture using this product, since it is designed for end grain sealing.
8/13/24       #2: Anchor Seal Waterbase Wax as a Furn ...
mauricio poli
this material is used only in the cut edges of logs,to avoid water entering and causing checking.
if you want to finish wood furniture with wax, you can use mohawk blue label
    • 2Sand
