Subject: Re: Dew point
Dew point
9/27/24
Kevin Member
Can someone clarify the wording or give me another example of the dew point recommendation in this post. It seems the poster is using dew point and relative humidity as 65. "A general rule for spraying lacquer (or shellac) is don't spray if the relative humidity is above 65%. A more accurate guide is don't spray if the dew point is within 20 degrees of the ambient temperature. For example, if the dew point is 65 degrees and it's 80 degrees in your spray area, don't spray unless you use retarder. You need more than a twenty degree difference between the dew point and temperature to be safe."
Thank you.
Kevin
9/30/24       #3: Dew point ...
Lary  Member
Website: http://www.larysanders.com
There is a direct correlation between dew point and relative humity and one can be converted to the other [FYI Dew temp = (100-RH)/5 degs F]. For finish what is important is how fast water evaporates or condenses on the finish. Dew point is used more often for "how does it feel" muggy, comfortable, dry. For me RH is easier to use at any temp because 100% is 100% at any temp, 50% is 50% likewise. For their example dew point of 65 F at 80 F deg is 60% RH. which agrees with their above 65% RH. But what if the temp is 70 deg? still 65% RH would work.
9/30/24       #4: Dew point ...
Kevin Member
Thanks for the reply.
