Subject: Re: Wax finish not drying
10/5/24
Oliver Vella
Hello, i am new here , be kind with me please &#128578;&#128591;
Applied a coat of sealer and 2 coats of wax to a maple floor and kept to instructions. Unfortunately wax remained wet, not to wet just tacky after a week. Weather did not help as it was quite humid but i reckon that this is bot the only issue. Both sealer and wax are of the brand Liberon. Has anyone experienced anything similar, how did you go about it? Any suggestions please?
10/6/24       #2: Wax finish not drying ...
Kit Mosden Member
Try calling Ron Ashby 707.391.4042. He is or was a Liberon dealer.
10/24/24       #3: Wax finish not drying ...
vivafenester Member
Website: http://www.vivafenester.com
Welcome! Don't worry; we're all here to help each other out. It sounds like you’re dealing with a sticky situation. Humidity can definitely affect the drying time of wax. Sometimes, it just takes longer for wax to fully cure, especially in humid conditions, so give it a bit more time. If it’s still tacky after a few more days, you might need to take action. Try using a fan or a dehumidifier in the room to help with airflow and reduce humidity. Just be careful with direct heat sources, as you don't want to damage the finish. If the wax is only tacky, you could also try buffing it with a soft cloth, which might help it dry out and remove some of the tackiness. However, if it doesn’t improve, you may need to strip the wax and start over, and Liberon has products specifically for that, so check their line for a suitable stripper. Finally, consider reaching out to Liberon directly for advice; they might have specific tips for their products. Good luck! Let us know how it goes!
    • 2Sand
