Subject: Re: Titan hvlp EP60x spray gun for Gallery paint
10/27/24
Steve A
I'm considering buying a Titan EP60X HVLP spray gun and turbine to spray Sherwin Williams Gallery coatings.
I'll be priming with Bins shellac. Anyone with experience or thoughts on this?
Formerly sprayed SW Cv with HVLP air assisted guns on cabinets. Just am not interested in setting up for that for now.
Thanks,
Steve
10/28/24       #2: Titan hvlp EP60x spray gun for Gall ...
Yavuz
Do not waste your money for HVLP.
Get your self a Airless or AAA. Ones you start reducing the paint for spraying easy with HVLP you will weaken the product.
Gallery or any other thick body WB paint with a green LP 308 you will lay that paint like a glass out of the can.
Good Luck !
10/28/24       #3: Titan hvlp EP60x spray gun for Gall ...
Steve A
Thanks for the advice.
This project has a lot of curved parts, carved columns, and detail. No experience with airless, but heard you need to move faster. So wondering if its a good fit.
Could i not get the 2.0 tip to handle the gallery thicker body?
Thanks for the help
10/28/24       #4: Titan hvlp EP60x spray gun for Gall ...
herb johnson
IF YOU want hvlp, don't get a turbine, you are limited to the power of a turbine, if u want hvlp, get or use ur compressor for this project.
a ca technology gun binks, dv, etc. sometimes u can pick a good on ebay especially if u repair ur own guns. and yes,with ur profiles u r spraying i believe an airless is a poor choice.
good luck, herb j
10/28/24       #5: Titan hvlp EP60x spray gun for Gall ...
Yavuz
Steve ,
I am a cabinet constructor and also finish all my cabinetry my self.
I have Hvlp, 4 stage turbine,Airless, Air assisted airless and Diaphragm Pump
i mean every kind of finishing equipment in my shop.
I know what their limitations and where they shine and i believe every job needs different equipment.
i don't use one equipment for every job :)
For your project and materials i believe airless is perfect .
you need a small orifice tip like 306 from tritech.that tip works exactly like hvlp. When you get the confidence jump up to FFLP 308.
HVLP is not easy to work with when your spraying thick body materials. Honestly they will never and ever work like a pump.period.This applies for Gallery type thick body materials.If you are spraying CV or Lacguer or poly thats a different story and hvlp is more than enough.
if you have a change try both and see for your self.
if i were you and money is not an issue i get my self a Titan Elite 2000 hopper and tritech 306 fine finish tip and do my work.
This pump is incredible. Maybe overkill but it opens a whole another world to your trade. You can swap the gun with a air assisted gun and hook a small compressor and here is your real time money maker. Hooper makes it so much easy to clean and spraying small batches with his 1 gallon hopper is effortless. i saw this machine the other day and i am impressed.
10/30/24       #6: Titan hvlp EP60x spray gun for Gall ...
Mastercabman
Like everyone said
Ditch the turbine idea
I have a Tritech T4 and use their fine Finish tips
Sure you will move faster but not too fast
AAA is also good but I'm liking my airless better!
11/3/24       #7: Titan hvlp EP60x spray gun for Gall ...
Nick Sinderson
I operate a 1 man custom finish shop and have and use darn near every possible type of spray equipment (AAA, airless, turbine hvlp, pressure pots with pneumatic sprayguns, and gravity feed set-ups) . Being a custom shop l spray whatever material the customer wants me to use, from Euro WB water or solvent 2k polys to nitro lacquer to WB solvent house paint and varnish. What spray set-up use depends on what material and quantity I'm spraying
For house paint the airless works great for big jobs (over a gallon) small jobs a pressure feed cup gun with a 2.2 tip. For Euro 1/2k urethane l use a 15:1 AAA for bigger jobs or a gravity gun 1.8/2.0 tip for smaller jobs.
For less viscous nitro, shellac jobs l use a 10:1 AAA set-up for bigger jobs. On smaller jobs l have some amazing Sata pressure/gravity feed guns.
If I'm spraying on-site l real like using the turbine for thinner material, so little overspray and the soft spray gives a very fine finish.
I also use a 2 gallon pot/gun set-up that l use to spray catalyzed vinyl sealer that l rarely clean just add more sealer as needed.
    • 2Sand
