Subject: Re: Vfd
Vfd
11/7/24
Jim b Member
I have a colmet panel control for spray booth fan and lights.can I add to that a var to control fan.would like to control that a bit. 30” fan 5hp 3 phase,has to be a way don’t want to purchase whole different unit.this is an old new unit never hooked up.,jim
11/11/24       #2: Vfd ...
herb johnson
what you can do although i am no electriciaqn
go out an buy a vfd twice the size of ur hp.
if you have a 3 buy a seven and half
same goes so for 5hp
use the vfd as ur motor starter disconnect switch.
also call colmet in texas they are very good, they might have another solution although they might throw the etl listing at u
again not an electrician but we never bought a control panel for our booths just bought a vfd twice the size of ur hp booth motor.
good luck herb j
11/11/24       #3: Vfd ...
Jim b Member
Thanks for the response herb,I will call colmet,I think they are rat now and hope there is a add on to there standard panel.my take on that is they will sell me on new unit u think was like 4 grand.definitely have to educate myself with this
11/11/24       #4: Vfd ...
herb johnson
or just sell the control panel on a woodworking site,
perhaps you can get a few dollars, i would call an electrician you know again i no electricina but they might be able to add a vfd for you. i believe you can do that externally,i think.
i will call a buddy of mine who is a long time smart as crap maint mgr and get his input for you
best, herb j
11/11/24       #5: Vfd ...
Jim b Member
11/13/24       #6: Vfd ...
herb johnson
sorry for the delay, yes a vfd can be mounted on the outside of the panel, ruff estimate for labor depending on market say about 500.00 and you can buy a good quality vfd for about 300 dollars for like a 3hp motor
good luck
herb j
11/26/24       #7: Vfd ...
Jim b Member
Collet came back with 2500!,not what I was thinking.i can get a weg (thats what panel is now or tech for 850-1000,they go down a bunch if I don’t need ip66 and go with ip20?
11/27/24       #8: Vfd ...
herb johnson
another resource would be to check out control associates in pennsylvania, and see what they want for a panel. these folks know what they are doing, i wish you the best as i am out of ideas..lol, to help out here. good luck and happy t-giving
11/28/24       #9: Vfd ...
Jim b Member
Thanks herb happy bird to you as well
