Subject: Re: Separation coat between oil stains
11/12/24
Simon Jordan Member
Looking for some advice as to the suitability of using Minwax spray laquer or a nitrocellulose laquer as an isolation coat between two old masters oil stains. I am using an Old Masters gel and wiping stain to create a faux burl finish and will then use another Old Masters wiping stain as a toning stain. Plan to finish coat it with more Minwax spray laquer and then rub out to a desired finish. Ideally I would use shellac, but just can't get any where I am at present.
11/13/24       #3: Separation coat between oil stains ...
mauricio poli
We use a NC sealer cutted 200% with lacquer thinner (wash coat)
Just one pass , between oil stain or wipping stains, to avoid the second color removes the firs one
Others coats must be NC sealer/top coat to avoid cracking
11/13/24       #4: Separation coat between oil stains ...
Simon Jordan Member
Thanks for the input Mauricio. How much drying time do you give the first coat before applying the wash coat? And can you build up the NC finish coat the same way as any other laquer to rub out?
11/13/24       #5: Separation coat between oil stains ...
mauricio poli
Simon, we wait 2 - 4 hs using a hot air fan, the first stain coat is more difficult to dry, depends how much stain you had applied.
The following coats dry really fast.
If you use a clean spray booth and drying room, there is no need to rub out.
Just some wool wax, if necesary
11/13/24       #6: Separation coat between oil stains ...
Simon Jordan Member
Greatly appreciate you input. I have just have one doubt. Will I get the same high gloss finish with just one coat of the NC finish as will get with the rubbed out laquer.
11/13/24       #7: Separation coat between oil stains ...
mauricio poli
Oh no Simon, you will have to apply several coats to reach the desired gloss.
Maybe you will have to spent some time doing samples untill you find out a good finishing schedule.
11/13/24       #8: Separation coat between oil stains ...
Simon Jordan Member
Thanks for the clarification. That makes sense. I was planning on applying between 5 and 10 coats of the minwax laquer.
11/14/24       #9: Separation coat between oil stains ...
Simon Jordan Member
I'll post some photos from the finished project. It's only an old cutlery canteen but it was the first thing my grandfather bought when he was demobbed after the war. They had handed in all their good cutlery and anything metal they could spare to make planes, so it I want it to look good so I can hand on to my kids.
11/16/24       #10: Separation coat between oil stains ...
john
amazion more shellac than you could ever use
11/16/24       #11: Separation coat between oil stains ...
Simon Jordan Member
They won't ship it to Mexico John sadly.
12/14/24       #12: Separation coat between oil stains ...
Paul Jenkinson Member
I feel your pain Simon. There are so many materials I was use to and familiar with during my prevous life in the States. Since moving to New Zealand I've had to rethink that way I finish.
But there is one material I couldn't work with out and that is shellac. And they wouldn't send it here. So I make my own.
I found a company that will sell de-waxed blond flakes in I liter packages, set up an account with a re shipper in the states, have the flakes send on to the re-shipper and then on to me here in little New Zealand. I generally make a "gallon" at a time which will last two or three months and keep enough flakes dry and on hand for another 'gallon" if something unexpectedly comes into the shop. Shellac is my go to and have had some weird problems with other sealers in the past. Since the refinishing I do take on are usually vintage or antique pieces it is almost universally compatible with those old varnished and NC lacquered finishes. Good Luck in sunny Mexico!
