Subject: Re: Radiator for incoming finish room air
12/10/24
Justin
Hi. We are planning to build a new addition and are planning to set up a new finish room. The one we currently have pulls air from the shop, and an open window we get along fine but now we are gonna put another fan in so I'm thinking if we have both running it will get too cold. I was wondering if anyone ever tried to make a wall opening and put a radiator in with a propane water broiler? Instead of just opening a window. Maybe would need 2x radiators?
24x24 Heat Exchanger
12/11/24       #2: Radiator for incoming finish room a ...
CraigM
NFPA 33 code requires 6 air exchanges per hour or 1 cubic foot per minute per square foot of floor space, it's unlikely the heat exchanger you posted would be able to keep up. Best bet is gas fired air makeup unit.
12/12/24       #3: Radiator for incoming finish room a ...
Justin
Right an air makeup would be ideal. This would be an open face booth in the shop not a closed in room, long term plan is possibly an air make up but for now we might try a double radiator setup.
12/13/24       #4: Radiator for incoming finish room a ...
gary
We do exactly what you are inquiring about except it is heated with an outdoor wood boiler. One 36" air exchanger didn't keep up with two 24" exhaust fans so we added a second sandwiched right up against the first and it works great. They are in an exterior wall in a room adjacent to the finish room. I have a very large wood boiler so it keeps up. I think you would need a fairly large propane boiler. I'm sure technically the cfm coming in through the air exchangers isn't enough but it works for us.
12/13/24       #5: Radiator for incoming finish room a ...
Justin Member
Awesome that is exactly what i was wondering about! Do you know how many btu your wood stove is?
12/13/24       #6: Radiator for incoming finish room a ...
gary
It is rated at 800,000 btu. It also heats 10,000 sq. ft. of shop space at 66 degrees. I am in NE Iowa so it gets cold here. If it is 10 below zero the boiler struggles to keep up so we try to be conservative with the exhaust fans.
12/19/24       #7: Radiator for incoming finish room a ...
Justin Member
Thanks Gary that is help full.We are in upstate NY so not too bad. We will have around 8,000 with addition most of that will be heated with mini splits. Hoping to heat the floor and pull air in through the radiators with water broiler in the new 20 by 56 finish room.
