Subject: Re: Spray stain
Spray stain
1/27/25
Jim b Member
I was wondering on the idea from total finish how they paired a aaa gun to a 1:1 diaphragm pump to spray stain evenly.?I have at times used my old turbinare gun to shoot stains,but that set up is not trusting(should throw away).I do have plenty aaa guns and would just have to buy the pump,thanks.they call it Frankenstein with funny video,just trying to make things simpler?
1/27/25       #2: Spray stain ...
herb johnson
wyith such a light viscosity you could just take ur pressure tank and hook it up to one of ur aaa guns. the diaphragm pump is a one to one, with just a max pressure of 100 psi. i would bet it would if you took a 413 tip or a kremlin 09-094 or a 12-094 tip you would do just fine. imho no need to buy another pump.
good luck herb j ps you can buy kremlin part that changes the jic to nps fitting, then you could get a binks 71-280 qtr in hose or similiar and one end 72-1303 to the kremlin gun and a 72-1306 to connect to ur pressure tank, the 1306 is a 1/4'' hose x 3/8 nps fluid fitting .
1/28/25       #3: Spray stain ...
Jim b Member
Herb believes it or not I do not have a pressure pot!I have I think 3 rusty brinks that need to throw away.i was thinking awhile ago to get one,but I am so hung on getting stainless version ,with agitator?
1/28/25       #4: Spray stain ...
herb johnson
i get it, maybe see if you can find on one the ebay and get a proof of concept before ur drop big bucks on s s pot., i am not saying that isn't the way to go, but i would testt it first. if u r going to go that way get an agiator with a back geared agitator, it has wide blades to get better agitation if ur solid spin out, a slower one a back geared is also more desirable if u want to sell it one day. also get the blades cermateched if that is a word, it makes them non stick lilke a teflon coating so to spec. i don't know how much that costs but well worth it. also get pail liners for ur pot. if i were going to get a new one or a used one on ebay etc, get a 5 gallon , and u get can 15mil rigid liners on ebay much cheaper than oem
u can disconnect the shaft and blades from the air motor might have to heat up the hex nuts etc because sometimes they use loktite on em
good luck
