Subject: Re: CAT AAA not building pressure
5/28/25
Peter Member
Hey guy. New here and was hoping someone could give me some direction. I have a CAT 15:1 pump and lately I'm noticing while spraying envirolac the pump starts double pumping, like it skips a stroke. This starts happening as soon as I go over 40lbs fluid pressure. Anyone ever experience this? Thanks for your help
5/28/25       #2: CAT AAA not building pressure ...
herb johnson
dry simple solution typically, the bottom ball check is dirty, as thepump does on the downstroke, because the ball is not seated the pressure bypass's the ball and seat. while u take this apart it is stone simple, inspect the ball and seat carefully to make sure there are no pressure worms, the other cause is the siphon hose is not tight enuf. it will then suck in air which causes the douible stroke. in about 90 percent of the cases this is the issue. to elimate the siphon hose have a hole etc, put a bucket of solvent directly and submerge the unit into the solvent ... if that solves ur issue the it is a bad siphon hoses but again, 90 percent is a dirty lower ball seat and ball
good luck
herb j
