Subject: Re: Recommendations for cleaning spray equipment
5/30/25
duster
Website: sunvalleywoodworks.com
We typically spray pre & post cat lacquers with our AAA spray rig.
An upcoming job has spec'd Varathane Diamond, which is water based. What would be the best procedure to flush out and prepare for that, and do the reverse when we're ready to go back to solvent based products?
5/30/25       #2: Recommendations for cleaning spray ...
Yavuz
Duster , I have the same rig and spray solvent like you. Never trusted what my rep says or the others.Everyone has different opinions and setup.Got my self a second hose dedicated to water base.
After using few times i got tired swapping the hose and changing the setup decided to buy another unit(Wagner/Cobra) :))) ohh well its just me.My time is more valuable than the money.
5/31/25       #3: Recommendations for cleaning spray ...
duster
This is a one off situation, I don't anticipate having to do this again. For that reason, I don't want to invest in another hose just for water base products. My first thought is to flush the hose and pump with lacquer thinner and then with water before attempting to spray the Varathane product, and vice versa when going back to solvent based materials. Is this a viable method, or is there a better way to do it?
5/31/25       #4: Recommendations for cleaning spray ...
herb johnson
easy, use ur typical cleaning solvent, then flush ur system with acra strip which is a w/b cleaner, works great follow the instructions with the dilution ratio. the repeat to switch back. btw, works even better when you warm the acrastrip, like to 90-110 degrees f
good luck
herb j
5/31/25       #5: Recommendations for cleaning spray ...
duster
Thanks Herb! I have some acra strip in stock which I use for cleaning the guns and tips. I'll give that a try.
6/1/25       #6: Recommendations for cleaning spray ...
herb johnson
warm it up it works even better but also if using w/b make sure your fluid hose fittings are stainless
good luck herb j
6/5/25       #8: Recommendations for cleaning spray ...
FM
Lacquer thinner
Denatured Alcohol
Water
Waterbased material
Reverse when going back to solvent
6/5/25       #9: Recommendations for cleaning spray ...
Jon
We spray solvents primarily, but switch back and forth occasionally. I flush with denatured alcohol which will pick up the water that gets left behind. Even after the Acra strip, I will will run some denatured alcohol the get the water out.
    • 2Sand
