Subject: Re: shaker cabinet door finish on rift white oak
8/11/25
RODNEY BLACKERBY Member
Had builder on a recent job call a said that the door panels are coming out a lot lighter on the panels than the frames of the doors when staining, panels are veneer panels, previous job was the same wood bought from the same supplier without any problems. but he used a different painter this time and now there is a problem, he hinting at me replacing them that would cost 7-8k. I told him that it could be how the finish was applied prepped etc did they condition or try to blend? when they seen there was a problem why would they continue? and what to say if replace the doors there not going to be the same problem? I know they used Sherwood pro oil stain, Is there a way to fix the problem? hoping they haven't applied any seal coat, any thoughts or ideal's would be greatly appreciated.
8/11/25       #2: shaker cabinet door finish on rift ...
If they opted for finishing them and screwed up why would that be on you? Sorry.
People tend to think stain is this magical fluid that makes everything the same color without work.
All woods absorb the stain differently. Veneer and solid take it differently. The only thing you should have done if you made the doors was give him a sample of the veneer for the panel and a sample of the solid so they could find out what works.
Finishing can be very difficult and that was something they chose to do likely to save money.
How'd that work out?
8/11/25       #3: shaker cabinet door finish on rift ...
Fixing it would be using a toner on the lighter stained sections. This would be a spray only application. And if the dark stained would is already too dark then they're up the creek.
8/12/25       #4: shaker cabinet door finish on rift ...
FM
This is a real concern with rift white oak right now. It has been used so heavily the last 6-7 years that the quality of the wood has gone down. Both hardwood and veneer. Color inconsistency is by far the biggest problem. True rift grain being the second. I warn every customer these days and if the stain color allows I try get them to use rift red oak. It takes real skill to do a high quality rift white oak job these days.
8/18/25       #5: shaker cabinet door finish on rift ...
JeffA
The problem is that the person doing the finishing doesn't have the skill to fix this issue. For many skilled finishers here they know how to make a shader/toner to apply after sealer to make some lighter woods blend in with darker. And it won't do any good now to try and help with giving some advice if they don't already know.
