Subject: Re: Remidiating & Finishing Posts w/Mold
2/16/26
Andrew Member
Looking for guidance from the experts on here. I'm working on a post & beam barn style projects with shiplap walls. The posts/beams will be finished with clear poly only; the walls will receive a slighly white hardwax oil finish (like a Rubio monocoat).
The posts were wrapped with poly while the slab was being poured beneath them, and the plastic was left on for too long, which resulted in some mold. I tried some sanding with 100 grit and it didn't really do much.
Any suggestions on how to fix this? Is this a job for oxalic acid? I'm concerned because there won't be any stain on these, only clear poly, so it will be difficult to hide any lines from where a product was used for stain removal.
View higher quality, full size image (1705 X 5550)
View higher quality, full size image (3568 X 5580)
View higher quality, full size image (1951 X 5712)
