Subject: Re: Finish over another
Finish over another
6/20/26
Fred Melton
I have been ask to apply conversion varnish over danish oil on a kitchen counter top I don’t think that it will work any body done this it is a very high end home or wood oldies oil be a better choice
6/21/26       #2: Finish over another ...
Leo G
I don't think it'll work either. The only combination I think MIGHT work is a product called MLC Isolante which is a 2K sealer designed to go over oily woods.
I would wipe that project down with acetone and then denatured alcohol and apply it. Let it dry overnight and then scuff lightly and apply whatever coat you want over it.
The other option might be clean it as I mentioned and then a vinyl sealer. I wouldn't trust that one as much as the Isolante.
6/22/26       #3: Finish over another ...
CraigM
I've done it spraying CV over vinyl sealer on walnut stained with Watco oil that has dried for a few days and it worked fine. In my experience, Odies won't protect much against water.
