removing air from opened 5 gallons of finish
2/28/15
Jim
Looking to preserve the best quality of finish when your 5 gal sits around and no one is asking for that sheen.
Thinking of something like the 3-m pps system where you can remove the diaphragm liner and lid/filter. Then carefully press down expelling the air and cap it.
Something for solvent lacquer and CV. I know for oil base paint they have bloxygen, but only helps oil base.
Other thoughts???
2/28/15       #2: removing air from opened 5 gallons ...
Buy some one gallon cans and fill to the top.
3/1/15       #3: removing air from opened 5 gallons ...
Jim
Very practical! I like it!
3/1/15       #4: removing air from opened 5 gallons ...
Leo G
Fill the canister with some non oxygen gas such as argon or CO2. Something you can get from a welding supply house.
3/1/15       #5: removing air from opened 5 gallons ...
Jim
Thanks Leo
When I contacted bloxigen they told me that argon is what they use and it does not work on solvent lacquers....... I will look into the CO2.
3/1/15       #6: removing air from opened 5 gallons ...
Leo G
Nitrogen is another one.
3/1/15       #7: removing air from opened 5 gallons ...
Paul Snyder  Member
Jim,
There's no need to remove the air in the container - it will not affect the quality or shelf life of the products you listed.
Oil-base finishes cure through a process of absorbing oxygen from the air. That's why replacing the air in the can with an inert gas prolongs the shelf life.
3/1/15       #8: removing air from opened 5 gallons ...
Jim
Thanks Paul! When you don't know one can imaginate problems.......
