Thinning Valspar Valtech Ultra Pre-Cat
4/8/15
Jim Conklin  Member
Website: http://www.jhconklin.net
A month or so ago I messed up thinning a gallon, thinning to 15% to 18% instead of the recommended 10% (got distracted mid way and recalled the error later). While spraying, I thought, "Hey, this is the sweet spot." The atomization was that good, and the layout on later coats was like ice.
I'm using a pressure pot set-up with the main gun as a CAT FE-FF (Feline).
The Valspar rep clucks at me for exceeding the TDS and the tech guy at our distributor merely says "Watch it on vertical surfaces." But no one mentions a technical reason.
Should I watch out for anything?
