Polyester
8/17/15
Greg Lemmen Member
Website: http://glresurrectionrefinishing@weebly.com
Long time finisher 30 years plus, mainly pianos now, currently using urethanes mostly, P.P.G., Matrix, Omni, etc. love the finish but would like to try polyester for the hardness factor as my pianos travel long distances in hot semis on their sides, sometimes get pad marks and that is unacceptable! Having trouble finding polyester paint! Any help out there?
8/17/15       #2: Polyester ...
chris
try Ilva products from Camger coatings.
8/17/15       #3: Polyester ...
Greg Lemmen Member
Thanks Chris!
8/18/15       #4: Polyester ...
sean
I used duratec polyester for 15 years. I'm out of the poly game now, but that stuff was hard as a rock. They have poly sealer for exotic woods as well as poly primers and clears. Super labor intensive to cut and buff though, so keep that in mind. Did high end furniture and shipped all over the world in any climate. Never had a problem. No mistakes though with poly. You do not want to have to strip that stuff!! You can get it through Hawkeye industries I believe. I know ML CAMPBELL is currently developing a poly coating, but it will be a while till that's available. Still in the R&D phase. Good luck!!
8/18/15       #5: Polyester ...
Leo G
MLC's 2K poly is called Polarion. Just shot some today. I certainly haven't gotten it tuned in though. Lots of orange peel. Pricing is pretty good. Comparable to Stealth. The catalyst is pretty expensive though.
8/18/15       #6: Polyester ...
sean
Polarion is a 2k polyurethane, not a polyester. I work for a MLC distributor and just got done spending 2 months playing with it for testing. MLC is developing a true polyester, but won't be avail for quite a while. Polarion is good stuff though. I like it.
8/19/15       #8: Polyester ...
JT
Milesi High performance European Wood Coatings have an excellent Polyester. www.milesi.us.
8/19/15       #9: Polyester ...
Greg Lemmen Member
Thank you everyone for all of your input.
8/23/15       #10: Polyester ...
Daniel Shafner  Member
Mason & Hamlin pianos are shot with Ilva which they get from Camger Coatings. The black colorant is a custom blend of colors, if you use la/p black then your pianos will look gray in comparison.
    • EX-FACTORY
    • Supergrit Abrasives
    • Apollo Sprayers Inc.
