Refinishing conversion varnish
10/13/15
Joseph Grove Member
Website: http://www.musserfarmwoodworks.com
I made a piece of furniture for a customer that is finished with white pigmented vinyl sealer and clear conversion varnish. It's been finished for 8 months. They now want another color. Can I scuff and spray either pigmented sealer and cv or just pigmented cv over the current finish? Please respond if you have experience. Thanks
10/14/15       #2: Refinishing conversion varnish ...
Shane
Do you have a meter to measure nil thickness? or really know how much you laid down on the piece? You shouldn't have a problem re-coating right over what you have done with just a tinted c.v. topcoat as long as your not way over millage. clean clean clean with some wash wash or weak solvent. Sand everything out really well and coat it...
10/31/15       #3: Refinishing conversion varnish ...
Rick Mosher  Member
Website: profinisher.blogspot.com/
To save the work of grinding so much finish off I would just thoroughly clean and degrease, scuff sand with 320 and spray a coat of 2K urethane pigmented finish in whatever sheen they want. Then I don't have to worry about mil thickness and future finish failure.
