Polishing dark wood
12/9/15
Joshua Johnson Member
Website: http://www.jaaronwoodcountertops.com
Hello all,
I've always had an issue polishing dark finishes. It always comes out a little milky no matter how fine of compound I use. Does anyone have a good idea on this? Thanks.
12/9/15       #2: Polishing dark wood ...
Kevin
need details on products used.
12/9/15       #3: Polishing dark wood ...
RobertJ
Great website.....beautiful countertops.
What sealer are you using....?
Watco/Tung oil can be polished via multiple applications and wet sanding between coats. 200 grit thru 2500 grit. Takes about two weeks to achieve high gloss.
12/9/15       #4: Polishing dark wood ...
Rick Mosher
You will need to post your finish schedule including what products you are using so we will be able to help you.
12/16/15       #5: Polishing dark wood ...
Roger Laster Member
I really like the design of the countertops. It would be good if you post some more pictures of the finishing you have done, so that we would be able to give right opinion on it.
convention collective commerce de gros
12/16/15       #6: Polishing dark wood ...
Hi guys,
Sorry, got buried there. Everything we do is conversion varnish. I've just got a top that's stained almost black and just can't quite get it through finishing without some trash. It's not terrible and can probably go without an work but I'd love to have an option of polishing it out. What I normally do is wet sand with 1000 then buff with gray scuff pads then white scuff pads. That works well with a clear coat but with the dark colors it makes it look milky.
12/16/15       #7: Polishing dark wood ...
Rick Mosher  Member
Website: profinisher.blogspot.com/
Sounds like your trying to rub out to a specific sheen other than high gloss. The best method I have found is using Abralon Pads on either a random orbital or straight line sander. I find the 2000 grit gives me around a 50% sheen.
Abralon Pads
12/19/15       #9: Polishing dark wood ...
Dennis Adrian
I recently finished a high gloss job, wet sanding up to 4000 grit abrilon pads and than buffing w/ 5,000, 9,000 and 11,000 grit rubbing compound. This got rid of the cloudiness and gave me an even and consist ant high gloss. A lot of work but beautiful results.
1/4/16       #10: Polishing dark wood ...
Thanks Rick,
Yes, I'm trying to do more of a satin sheen. I'll give those pads a try. Thanks again.
