Finishing of redwood tables. Indoor use
12/30/15
Russ Sitaro
My boss has me finishing a redwood table that we made from reclaimed wood from old water tanks. The product is professional Hard Waxoil by Blanchon. Has anyone ever used this product and is it good for a table?
He is looking for a uniform sheen. I don't think that this is the right product but he is the boss. Any input will be helpful.
12/30/15       #2: Finishing of redwood tables. Indoor ...
Paul Snyder  Member
Website: finishing.tips
Russ - that's a nice looking table and very sturdy as well....
Blanchon Hard Waxoil contains a drying oil (e.g., linseed oil), a natural wax (e.g. beeswax or carnuba), some oil based polyurethane resins, and solvents. The finishes in this category are best used on wood items that are not subject to a lot of wear and tear (e.g., wood sculptures, lamps, etc.) and/or when a film forming finish is not desired. If the goal is to avoid the look of a film forming finish and/or market the finish as environmentally friendly, then this product meets the needs. There are a number of brands that are very similar to this product - see the article below.
This finish has the following properties;
  • Easy to apply
  • Easy to repair
  • Good clarity
  • Low sheen (flat - matte)
  • Close to the wood look – does not form a film on the surface of the wood.
  • Poor overall durability (abrasion resistance, moisture resistance, stain resistance, solvent resistance, heat resistance, and household chemicals/cleansers)
  • Slow drying and cure time
  • Requires Maintenance - The finish must be reapplied as often as it wears down and starts to look bad. Frequency is determined by use.
  • CAUTION - Rags used for application can spontaneously combust (start a fire as they get hot while drying) - dispose of properly
FYI - Professional finishers usually want to use a coating that offers the appropriate amount of protection relative to the use of the product. For tables, the best finish is usually conversion varnish, catalyzed polyurethane (2K-PU), or polyester depending on the specific uses and desired appearance. These finishes offer a LOT more protection than an oil/varnish blend mixed with wax.
The chart below comes from the 1999 version of the Architectural Woodwork Quality Standards (AWI 1500) and shows the various properties of different types of finishes. Oil finishes are listed in the column labeled TR-0.
I’m also attaching a copy of Bob Flexner’s article on oil finishes for your reference. It explains the basic properties and limitations of oil finishes and oil/varnish blends.
View higher quality, full size image (572 X 708)
Oil_Finishes__Their_History_and_Use_Bob_Flexner.pdf
12/30/15       #3: Finishing of redwood tables. Indoor ...
Paul Snyder  Member
Here's the highlighted version of the article.
Oil_Finishes__Their_History_and_Use_Bob_Flexner_Highlighted.pdf
