Crackle finish
12/28/15
Mike Member
Has anyone had any success using conversion varnish to achieve a crackled look? Using Blue Ridge products.... Thanks
12/28/15       #3: Crackle finish ...
JimHerron
Spray it over an oil based finish, you'll get a crackle finish.
I found that out unintentionally, however the customer loved it.😂
12/29/15       #4: Crackle finish ...
CraigM
Not sure about CV, but Mohawk makes a crackle lacquer
Crackle Lacquer
12/30/15       #5: Crackle finish ...
Paul Snyder  Member
Website: finishing.tips
Mike,
Lacquer is used to make a crackle finish - it's an evaporative finish - not a cross-linking finish. Many brands offer a crackle lacquer.
You can top coat crackle lacquer with conversion varnish for added durability. Just one coat though - otherwise you risk wrinkling.
Check with your supplier to see what they have....
1/4/16       #6: Crackle finish ...
Rick Mosher  Member
Website: profinisher.blogspot.com/
You can do the crackle with hide glue and latex paint, seal with a wash coat of vinyl sealer and then top coat with CV.
