blopentine?
8/27/16
Al Fortunato  Member
Website: http://www.alfortunato.com
On many DIY forums posters are talking about "blopentine", a 1:1 mixture of Boiled Linseed Oil and Turpentine. They are using this to "feed" dry wood prior to applying a new finish or paint.
I tend to not believe that wood does not need to be fed, for any reason. Once the wood reaches EMC, nothing more is needed other than a quality finish to protect the wood.
Any other opinions out there? Gene Wegnert if you are reading this, what is your opinion?
8/27/16       #2: blopentine? ...
Paul Snyder  Member
Website: finishing.tips
Al,
"Feeding" wood is foolishness and the myth has been passed around for many years. Here are some links to previous discussions on the subject;
http://www.refinishwizard.com/phpbb/viewtopic.php?t=1889
http://com
munity.woodmagazine.com/t5/Finishing-and-Refinishing/Deep-Penetration-a-Myth/td-p
/416223
http://forums.finewoodworking.com/fine-woodworking-knots/general-discu
ssion/hardening-wood
8/27/16       #3: blopentine? ...
You ever seen an old piece of furniture or wood that had boiled linseed oil "fed" into it? Turns almost black. It's not a professional use finish, especially considering the time it takes for it to dry. Those ideas are discussed by folks that BS on the internet a lot more than they work in their shops.
8/29/16       #4: blopentine? ...
Al Fortunato  Member
I've always been of the opinion that "feeding" furniture is not required, but not sure about old house wood that has been stripped and will be repainted, since I don't do any of this stuff. Thanks for confirming my thoughts on this.
