Mixing Finish Brands
9/29/16
Kevin
I was wondering how many of you in practice would use say, one brand of stain and another brand of topcoat. With all of the liability that comes with this, it still seems to be pretty common practice. I have stayed away from this, but would like to explore it as an option. I guess testing is key. All solvent, mainly talking about spray and wipe stains under cv and sometimes precat. Just curious.
9/29/16       #2: Mixing Finish Brands ...
RobertJ
All the time. Mohawk stains with MLC topcoats. ICA stains with all sorts of topcoats!
9/29/16       #3: Mixing Finish Brands ...
Paul Snyder  Member
Website: finishing.tips
As long as you understand the properties of the products you're using, the brand name on the can doesn't matter.
Anytime you're not sure if any products are compatible, just post a question and name what you're planning to use.
9/30/16       #4: Mixing Finish Brands ...
Folz Custom Cabinets (Joe)
Can I used MLC clawlock 2 primer and topcoat with Chemcraft 24 topcoat?
9/30/16       #5: Mixing Finish Brands ...
Eric Member
I use all sorts of stains glazes and pigments with my top coats..
I only use Sherwins coatings..but have used all from, Valdspar, ppg, mlc, Becker and Mohawk and Gemini..
It's ok to intermix the stain brands with the coatings..just don't mix the coatings..like sherwin sealer and Gemini lacquer..
Tho on record..I was doing a white cv sample and used sherwin surfacer with a Gemini cv and worked fine..in fact it's still in file..4 years now
9/30/16       #6: Mixing Finish Brands ...
Kevin
Thanks. I have been using campbell products and am very familiar with their stains,glazes and dye systems, not to mention having cabinets full of them. However, I am starting to prefer chemcraft for cv, precats, and 2k poly. Seemed safe, and I have done a few small jobs combining the two, just wanted some reassurance I guess.
9/30/16       #7: Mixing Finish Brands ...
Paul Snyder  Member
Joe @ Folz - Chemcraft 24 topcoat is a post-catalyzed conversion varnish. It's important to use a primer that is also post-catalyzed. The Clawlock primer is and will work fine. Just be sure to give it enough time to cure properly before top coating. Follow all the standard application and re-coat directions that are described on the data sheets.
    • EX-FACTORY
    • Quickwood
      Quick Wood specializes in finishing machines and brushes to finish any size and surface since 1975.
    • Apollo Sprayers Inc.
    • Supergrit Abrasives
