Asturo Eco/SSP Spray Gun Problems
10/7/16
DanShaf Member
Many years ago I bought an Asturo Eco/SSP spray gun. This was when they first introduced this low CFM gun. I have lost my spray gun wrench for this gun. It was a manufacturer-specific pin spanner wrench.
The fluid nozzle and air cap are one single unit. My air cap ring is "stuck" to the baffle and I can't get my gun to batten down so that everything is air tight. I've tried soaking the air cap and baffle in acetone, that hasn't given me any success.
Might I borrow anyone's Asturo gun wrench? I hate to ask...
I have been a contributing participant on this forum since the forum began.
10/7/16       #2: Asturo Eco/SSP Spray Gun Problems ...
jonathan mahnken
I have an eco ssp and wrenchBut Im in ventura Ca. Walcom also makes the same spanner wrench. Homestead finishing might be able to hook you up much cheaper than the asturo distributor. You could also try a set of adjustable snap ring pliers. Just a thought.
P.S. How do you like the co ssp? I originally bought it be cause I was doing a lot of on site work with a small compressor, But Ive been thinking of upgrading/trying something "better because I mostly run off of shop air now.
10/8/16       #3: Asturo Eco/SSP Spray Gun Problems ...
DanShafner Member
Snap ring pliers might do the trick, thanks!
Regarding Asturo, in theory this was supposed to be an amazing gun, with amazing machining, and amazing air flow technology. Who knows what it isa now --AOM America-- if it's the same Asturo that was made years ago or something Asian, who knows? And what of the quality of the gun made these days.
The gun had so much promise and I took it out to give it another try. I wanted to do either a pressure feed set up or an Asturo K24 dual diaphram pump.
The compressor that I'm accessing has enough CFM to feed a Stuhr dual pad rubbing machine, but it seems to me that I am starving my gun for air volume. And that's why I wanted to give that low CFM Asturo gun another chance to do something good.
I'm optimistic that the Asturo can do something. It has been so long since I used uit, but I seem to recall that it was a very slow gun, meaning for piano lids and conference tables it will be more trouble than it's worth.
I do hope that the snap ring pliers will be a good first step in the rehibilitation of this Asturo gun.
10/8/16       #4: Asturo Eco/SSP Spray Gun Problems ...
jonathan mahnken
I use my eco ssp(2 gal pot) all the time for clears, and yes it does a good job but it is slow. I bought mine about 7-8 years ago, made in Italy. I tried the dual diaphragm pump but I found its operation kind of crude so I returned it immediately. They wanted to sell me another few hundred dollars worth of parts to make its operation more smooth... Now that I have a little more air at my disposal Im curious if there is anything out there that I might like better that has a little more speed and atomization to it that isnt a total air hog.
10/9/16       #5: Asturo Eco/SSP Spray Gun Problems ...
DanShaf Member
Besides air-assisted airless?
CA Technologies have a great assortment of guns, including low CFM guns.
I got the Asturo K24 dual diaphram pump for $50, I couldn't turn that down.
I'm about to try out a Binks Mach 1 BBR. They don't make that anymore. Some of their air caps need more than 22 CFM, but some will only eat 13 CFM, so it depends on the set up of the Mach 1. I have a 92 air cap, but only a 1.2mm fluid set. That's super thin, maybe less than 15 seconds in a Ford #4 cup.
10/9/16       #6: Asturo Eco/SSP Spray Gun Problems ...
jonathan mahnken
Thanks Dan. I have been wanting to try a C.A.T gun for a while. Have you used any of them? Any recommendations? And I would love to upgrade to AAA if I ever come across the extra 2 grand :/
10/9/16       #7: Asturo Eco/SSP Spray Gun Problems ...
DanShaf Member
I have used their low CFM gravity guns and attached cup guns, I don't know the models. They aren't slow, they are great production-friendly guns and the quality of atomization is superb. Demo them if your distributor allows. You'll be impressed.
10/9/16       #8: Asturo Eco/SSP Spray Gun Problems ...
DanShaf Member
The adjustable snap ring pliers didn't work. The pins fit in the air holes of the baffle but the whole wrench is too small to work as a pin spanner wrench. My next try will be to grind down the tips of some needlenose pliers to see if that will work to unscrew the air cap ring from the threaded baffle.
10/10/16       #9: Asturo Eco/SSP Spray Gun Problems ...
Bob "Boardman" Borders Member
Yes, Dan Shaf, I recognize you from this and other sites. I have a wrench for the Eco S (not SSP), but I think it would probably work for you.
I could send it to you, but would like it back. If interested email is tmgrp@optonline.net
