cedar tannin bleed
11/2/16
John Member
I am having a helluva time with cedar tannin bleed. I run a high volume exterior shutter shop and get orders of up to 40 pairs of cedar raised panel shutters. I am desperate to find a solution to cedar tannin bleed. I've tried XIM with unsatisfactory results, and our moisture content is good at 8%. Any advice is appreciated. I run a high production shop so I need a product or technique that doesn't involve a lot of steps(priming stiles, rails, and panels before assembly).
thanks
11/2/16       #2: cedar tannin bleed ...
Paul Snyder  Member
Website: finishing.tips
Two coats of XIM X-Seal should do the trick (see data sheet below). If not, you may want to cross over to a catalyzed poly coatings system and use a primer like the one from ILVA (see data sheet below).
XIM_X_Seal_Primer_Sealer_Stain_Blocker_TDS.pdf
ILVA_Stain_Blocker_Primer.pdf
