Refinishing
2/27/17
Patricia King
Can post catalysed solvent b
ased conversion varnish be sprayed over a water based UV cure finish?
2/27/17       #2: Refinishing ...
Paul Snyder  Member
Website: finishing.tips
Probably - but you should do a test on the back of something to make sure. You're looking to see if the new finish causes wrinkling or lifting and to make sure it has good adhesion.
2/28/17       #4: Refinishing ...
Nick
I have done this successfully but the key to get anything to stick to a uv cured finish (that stuff is hard) is a very through scuff. I've found finer is better then coarser so 400 grit on the RO until it's all been hit.
2/28/17       #5: Refinishing ...
Patricia King
Thanks for your responses
    • Supergrit Abrasives
    • Apollo Sprayers Inc.
    • EX-FACTORY
