Mixing different brand names of rubbing stain?
12/18/17
Jeffer Member
Hi,
I'm taking over managing a wood shop which has many different brand names of rubbing stain in stock. Going back decades.
Gemini, ML Campbell, Glidden, Zar, McCloskey, Duran, Olympic, and many more.
Is it safe to mix different brand names of rubbing stain together? Will the finish still reliably adhere on top of it?
I think the previous manager of this woodshop did just that -- he mixed different brand names together. But I'm hesitant.
Does anybody have any experience in this? Good or bad?
12/18/17       #2: Mixing different brand names of rub ...
Jeffer Member
I forgot to point out that all the rubbing stains are oil based.
12/18/17       #3: Mixing different brand names of rub ...
kevin
out with the old in with the new.
Those old cans of stain will do nothing but cause you headaches. Get rid of all of it and start with fresh product. Use products that are designed to work with each other as a system. This way you can avoid failures.
12/18/17       #4: Mixing different brand names of rub ...
Jeffer Member
Thanks, Kevin.
This reflects my sentiments exactly. I think the former manager liked to Russian Roulette with his approach. :-)
12/18/17       #5: Mixing different brand names of rub ...
Jeffer Member
*play Russian Roulette
12/19/17       #6: Mixing different brand names of rub ...
Bob
Why risk messing up a expensive cabinet job just to save $50 on a can of stain. I discard any stain or finish that is a year old or so. Just not going to take a chance.
12/19/17       #7: Mixing different brand names of rub ...
Paul Snyder  Member
Website: finishing.tips
The previous guy probably knew the properties of the stains and how to use them successfully. When you're not sure about the properties of the products you have, there's a small chance you will do something wrong.
Two choices - learn more or stick with the products your rep sells and follow the directions that come with them.
12/20/17       #8: Mixing different brand names of rub ...
Michael Foscone  Member
That's insane, and asking for problems
