Fuji HVLP with off-brand spray gun?
12/16/17
Gary Member
Website: http://CraftsmanContractingCT.com
Hey guys, Iíve got a quick question regarding my Fuji HVLP turbine. Iím looking to buy a cheap gun to dedicate to spray primers. The guns Iím looking at, like the cheap ones from Harbor Freight, have a 1/4Ē male outlet on them. The Fuji hose has what looks like a 3/4Ē femal quick connect, but I canít find any specs on-line with information on the Fuji hose. Does anyone know if (a) can I use one of these cheap guns with a Fuji turbine, and (b) what fittings do I need to make the conversion?
Thank you in advance,
Gary
12/17/17       #2: Fuji HVLP with off-brand spray gun? ...
I can't say with 100% certainty but id guess it'd be close but I dont think your going to get the volume of air through the 1/4" inlet in a conventional hvlp gun and relying on the turbine to feed the air. The turbine is not a compressor.
I could well be wrong but I'd highly doubt it will work. The fuji turbines are just using a garden hose thread and quick disconnect and fittings to adapt your 1/4 port to GH are available at the hardware.
I'd just bite the bullet on a second gun from fuji.
12/17/17       #3: Fuji HVLP with off-brand spray gun? ...
From Fuji:
"Generally speaking, HVLP turbine motors produce over 100 CFM (cubic feet per minute) at 3 Ė 8 psi. (pounds per square inch) depending on the model of motor. Compare this to a typical high pressure set-up where 45 Ė 60 psi at 8 CFM would be the norm. "
3-8 psi ain't gonna cut it with a conventional gun.
12/17/17       #4: Fuji HVLP with off-brand spray gun? ...
Pat
There are cheap(er) turbine guns available. I've seen them on eBay. I bought a Titan Capspray gun for around $250, but there are cheaper ones than that. $250 isn't exactly cheap, but even at that price the quality is so-so in my book.
Cheers,
Pat
12/18/17       #5: Fuji HVLP with off-brand spray gun? ...
Ken Member
I would say no. Those are conversion guns. High pressure in, the HVLP conversion happens in the gun. Do a search on HVLP conversion guns.
2/23/18       #6: Fuji HVLP with off-brand spray gun? ...
DanShaf Member
The answer is flat no. You need a turbine gun - any turbine gun - to use with your turbine.
