Painting Flex Trim Mouldings
1/26/19
Jason
Hello All,
I hope you are all having a great weekend! My question is this: I am having a problem finishing this substrate called "Flex Trim". It is a trim that seems to be made out of somekind of rubber material it is made so that it can "flex" to any position. I am using Sherwin Williams White Lacquer Undercoater for the primer and after about an hour the primer starts to crack. Im sure this is because of Flex Trim moving a bit and the primer is hardening so it is inturn causing it to crack. The clients have chosen a catalyzed varnish for their topcoat but im sure it will do the same thing. If anyone has any tips or ideas please let me know. The trim says it can be painted or stained but im sure they mean with a latex type of paint. I didn't want to go that route but I may have to.
Any advice would be helpful.
Thanks Again,
Jason
1/26/19       #2: Painting Flex Trim Mouldings ...
mauricio poli Member
Hello , I would call your preferred coating company and ask for technical advices, I believe you have to use some kind of adhesion promoter first, and after this a PU system. Maybe everything will use hardener, so it will be a kind of industrial process with specific chemicals.
Good Luck
1/27/19       #3: Painting Flex Trim Mouldings ...
mike
this is from their website
looks like no lacquer or primer
https://flexiblemouldingconcepts.com/installation-tips
1/28/19       #4: Painting Flex Trim Mouldings ...
Shane
that substrate is made to be installed and then painted in place with interior latex coatings..... No solvent borne finish is going to make the cut for that substrate flexing..
1/29/19       #5: Painting Flex Trim Mouldings ...
DannyB
There are solvent borne that would work here, like polyureas.
They are not generally pleasant to use (even in single component moisture cure versions)
As everyone else said, either install and then paint it, or better yet, i'd run the heck away.
This is not worth your time and energy.
2/5/19       #6: Painting Flex Trim Mouldings ...
Mark Member
Website: http://www.austinpaintpro.com
I would recommend a water based Latex Paint, because it has some flexibly to it and I feel like I would be less likely to crack in my opinion.
8/5/21       #7: Painting Flex Trim Mouldings ...
Philip Member
Latex paint is a good one to solve your problem. I used it when I have the same problem and it works.
chattanooga home maintenance
12/21/21       #8: Painting Flex Trim Mouldings ...
Jordan Beaubien Member
You might wanna call some plasterer to cut the board correctly.
tree removal service
