Chemcraft Conversion Varnish
2/24/19
Garen Pletzer
I sprayed SW conversion varnish for a bunch of years. Then picked up a distributor with chemcraft. Always wanted to try them. I have been using the conversion varnish and I dont seam to think it has the same hardness as the SW water white CV. Any thoughts on this? I have been using the correct cat and the correct ratio for mixing. I had to switch back for this job i am working on. I needed that harder finish. I also have tried Chemcrafts poly finish. was alright but more expensive. I am doing something wrong?
2/24/19       #2: Chemcraft Conversion Varnish ...
Tyler
That doesn't sound right . Which CV are you using? We use plasticolor, and plastofix light it is a really hard and resilient finish.
2/24/19       #3: Chemcraft Conversion Varnish ...
Garen Pleter
using the chem24 sealer and top coat.
2/25/19       #4: Chemcraft Conversion Varnish ...
Tyler
The chem24, as is in its name, takes longer to cure than a conventional CV, while also giving you a full 24 hour potlife. If you try the plastofix light you will not see the initial softness you're dealing with right now, but will go back to a more conventional 8-12 hour potlife
2/25/19       #5: Chemcraft Conversion Varnish ...
Gerry
We use the Chemlife 24 and don't find it soft at all. Are you insuring the drying room is at 70 degrees. If it is not warm enough it will never get hard.
Also I would recheck your cat mixture. Chemlife 24 is a very durable product.
2/25/19       #6: Chemcraft Conversion Varnish ...
dub
I spray SW Kemvar CV and also tried Chemcraft's CV for a couple of projects and found it to be less durable. I actually have two identical cabinets in my house with one topcoated with SW and one with Chemcraft. They are in different locations and may be subject to different amounts of wear, but the Chemcraft one shows the dings/chips, etc. more than the SW.
I also think the SW pigmented conversion is more durable when self sealed rather than using a primer/surfacer.
dub
2/26/19       #7: Chemcraft Conversion Varnish ...
Garen Pletzer
I have checked the amount of cat and room temp is above 70. Have air makeup and spray booth. I have samples here from over a year ago and it still not as hard as my desk that has the SW. I will try the plastofix. The chemcraft seams to lay down great but if i dont get a hard finish it doesn't mater. Thanks for the tips.
2/26/19       #8: Chemcraft Conversion Varnish ...
Jim Clark  Member
Sounds like bad activator or not enough
added.
2/27/19       #9: Chemcraft Conversion Varnish ...
mauricio poli Member
Hello !
The best way to compare those materials is to prepare a big panel, and apply side by side both products at the same time, same viscosity,same coats, same temperature
Wait 3 day and make the coin test.
Wait 30 days and make the test again
Hugs
12/11/23       #10: Chemcraft Conversion Varnish ...
Walter Kerr
Try the E-Var Conversion Varnish 421-80xx from Chemcraft. 8-hour pot life with 10% catalyst 873-0870. We have sold and used this for many years.
Ther is a vinyl sealer that goes with it, or it can be used as a self-seal 2 coat system. Water clear and extremely durable.
