Graco Merkur ES 15:1
4/19/15
Nick Member
Anybody using the Graco 15:1 Merkur ES?...My dealer is making me an offer on one that is a pretty large savings over the Kremlin EOS 15:1 that I've been looking at and I'd like to hear some first hand experience with using one; the good or the bad.
The pump will be used as a dedicated solvent borne pigmented CV pump...it would not see a lot of use, around 100 gallons a year. It's the stainless steel model.
4/20/15       #2: Graco Merkur ES 15:1 ...
herb johnson
both very good machines and graco is known for its pumps etc.
another cabinet shop has one and it has run for quite a while.
i believe he said it is all stainless steel so the acid catalyzed is no issue and the pump has virtulaly no spray winks which suprised me for the size pump that is
it will be much cheaper to repair
either systems works just fine, but kremlin has a bullseye on the them and many mfg have come out with great aa systems
good luck herb j.
4/20/15       #3: Graco Merkur ES 15:1 ...
Jim
Nick,
I have had this pump for two years. Works great and very happy with performance. We spray a lot of conversion varnish solvent.
4/20/15       #4: Graco Merkur ES 15:1 ...
Nick Member
Thank you for the replies...I'll be buying the Graco!
5/13/15       #5: Graco Merkur ES 15:1 ...
Denny J
Good choice. Graco Merkur is a very high quality product
6/22/19       #6: Graco Merkur ES 15:1 ...
dan shaf Member
I just tried one for the first time spraying ML Campbell's Turino. Flawless glass-smooth finish. The fan pattern was astonishing. The ergonomics of the gun design are more than impressive.
    • EX-FACTORY
    • Apollo Sprayers Inc.
    • Supergrit Abrasives
