What to do with honey oak?
1/9/20
Morning everyone, I was wondering if there was any solutions for changing the color on the old honey oak.
I have a beautiful spiral staircase with light oak spindles and railings. It is 20 years old and was finished with a wiping stain and either Becker faucet or deluxe. I would like to finish it with something a lot darker, does anyone have any recipes for doing this. I was going to try tinting a similar lawyer and spray it and see if I could make it look darker. Plan B would be to strip and sand it all and start over.
I was hoping to spray it with ISF water based 2 part. .
1/9/20       #2: What to do with honey oak? ...
Best to use the same finish that is currently on it. Put a compatible colorant into it and spray it on. You'll have to be good with the gun to keep the color consistent. I suggest doing it in layers with a lighter toner. Build until you get the desired darkness.
It will hide the grain if you go dark with this method. Using dyes vs pigments for colorants would keep the grain more visible.
