Coating over prefinished ply
4/2/20
One cabinet box option I use is prefinished birch ply, 3/4 inch gables and 1/2 inch backs. I need some black toe kicks for a project and the 1/2 inch scraps would work perfect. I was hoping to scuff up the faces with some 320 grit and then spray some wb sayerlack or ISF.
Just wondering if anyone has done this and if there would be any issues?
4/2/20       #2: Coating over prefinished ply ...
Tyler
I usually orbital them with 120 grit until all of the shine is gone, then I paint them, haven't had an issue yet.
4/2/20       #3: Coating over prefinished ply ...
Jared E
Same as Tyler although sometimes the prefinished stuff is lousy with ripples and might benefit from a calibrating run through your widebelt.
4/2/20       #4: Coating over prefinished ply ...
Thanks for the help, I didn’t even think to go with a lot courser grit or to run them through the widebelt.
4/2/20       #5: Coating over prefinished ply ...
Nick
320/ 400 grit with the orbital has always work for me be it clear or pigmented.
4/3/20       #6: Coating over prefinished ply ...
240 grit. Treat it as the primer coat.
4/3/20       #7: Coating over prefinished ply ...
Anthony J. Darbenzio  Member
Do it all the time. Scuff with 150 then shoot.
Never had a problem.
4/3/20       #8: Coating over prefinished ply ...
david zaret Member
150, 180, or even 220, and i the sayerlack will stick with no issues.
4/8/20       #9: Coating over prefinished ply ...
Bart
Black melamine is the answer. I've done both. The finishing takes time and really isn't close in durability. When I've done I hit it 120 and then Bin shellac primer for a good bond/barrier coat and finished with GF black poly. Nice but a vacuum after time will scuff it off. A sheet of 1/4" black melamine is cheap.
my2cts
4/9/20       #10: Coating over prefinished ply ...
Thanks for all the help, I was thinking about using black melamine or black plam. I am a little hesitant to use particle core as not everyone is diligent in cleaning up their spills. I guess if it is caulked nicely it would be fine.
