Storing AAA pump
5/4/20
Pascal
Hello,
Just recently got a merkur ES 15:1 pump (Stainless).
I was wondering how do you guy store it. Manual states Nothing about it. Everywhere I see instruction for airless pumps.
I would guess that since the pump part of the system is basically airless it would be the same. instructions also speaks about prime tube which I guessed is just a short fluid hose whose function is just to do the inverse of the suction tube.
So, what do you guy use. right now I saw mineral spirits/pump armor/antifreeze.
And for circulating storage fluid, since we Don't circulate it into the fluid hose I was thinking about buying a 1/4 npt adapter and a small piece of hose to make my DIY prime hose. Or do you guy just use the fluid hose to fill the pump. I could then empty it using compressed air.
5/24/20       #2: Storing AAA pump ...
Daniel Shafner
Hi. Do this.... search Woodweb using "Acrastrip" or "Acrastrip 600". You will find useful information that will answer your questions about storing the pump. Acrastip 600 is a paint purge cleaning liquid. I get mine from Grapek-Bates, approximately $50/gallon including the shipping costs. Good luck with the Merkur, the G40 and the G15 guns are the most ergonomic air-assisted guns there are.
Email Graco or call their tech support. They will advise you all there is about shut down and storing.
