Surfprep abrasive/pad advice
6/1/20
Matt V Member
Website: http://www.silverlake-designs.com
New to using my Surfprep 3x4. I am looking for advice on which pad/abrasive schedule you're using between sealer and topcoats to get a smooth finish? I have purchased a number of the foam pads (which seems like overkill). What are the main foam pads you use between finish coats?
6/1/20       #2: Surfprep abrasive/pad advice ...
Jim Clark  Member
I use the newer thin Mirka red scuff pads
over my sealer coat, before top coating.
They work much better than the 3M ones
I used to use.
6/1/20       #3: Surfprep abrasive/pad advice ...
JoeW Member
If your schedule includes one or two primer coats - followed by two finish coats, I would use surf preps fine red pad after each prime coat.. Then very fine red pad between the finish coats.
If your only using one finish coat, use very fine after last prime coat.
Works great get me. I use the MLC waterborne products.
6/1/20       #4: Surfprep abrasive/pad advice ...
I prefer an abrasive over a scuff pad. I want any nibs or imperfections cut off and not buffed. I use Sia Soft foam backed abrasive.
6/2/20       #5: Surfprep abrasive/pad advice ...
Matt V Member
Thanks, everyone for your responses. I am finishing a door right now and will be trying the fine and very fine SurfPrep pads.
