Spraying oil through AAA
6/2/20
Kevin Member
I would like to try to use my kremlin to spray an oil finish, due to the large size of the panels. I've been doing it with a cup gun but having trouble with lap marks. Is this asking for contamination issues down the road? I switch from solvent to water, clears to pigments, but a little worried about this one.
6/2/20       #2: Spraying oil through AAA ...
herb johnson
water to solvent is the toughest one to deal with and you have done it , i wouldn't be concerned with oil based
good luck
herb j
6/2/20       #3: Spraying oil through AAA ...
I highly recommend a wide paint pad, or floor wool mop designed for applying floor finish. No need for atomizing the oil in the air when the pad will apply it just as fast. No cleanup either!
6/3/20       #4: Spraying oil through AAA ...
Pat
Similar to Rich C, I use a foam roller followed by foam brush. This works well as long as there's no (or minimal) detailing on the panel. Near 100% transfer efficiency using this method!
I'd also worry about the atomized oil finish getting all over my spray area.
Cheers,
Pat
6/3/20       #5: Spraying oil through AAA ...
nicko
I have used a garden pump sprayer to stain a bunch of oak interior doors. It worked well for spray and wipe stain.
Nicko
6/4/20       #6: Spraying oil through AAA ...
Daniel Shafner
Based on our experiences spraying Epiphanes vs brushing it on, we preferred the sprayed method. The suggestions for you to use a brush don't at all answer your question. A thorough rinse with lacquer thinner to clean your lines of the oil finish will be ticket to success. Yes, your overspray will stay wet at the same length of time that your finish stays wet, but that's what spray booths are all about.
6/5/20       #7: Spraying oil through AAA ...
Kevin Member
Thanks for the replies. I've gone ahead with spraying the finish (sikkens door and window) and so far am happy with the results. Raised panel wainscoting, face frames, doors, etc. Never could get these finishes to lay as smooth as I wanted without spraying.
