Question about spray tip sizes
6/23/20
stan merritt  Member
Website: http://www.basicwood.org
Trying to understand why smaller orifices for spray tips are suggested for thicker material. For example, C A Tech or M L Campbell (don't remember which) suggest a tip size of .011 for Krystal CV but .009 for Clawlock. Keep it simple pleas. :)
Thanks !!
Stan
6/23/20       #2: Question about spray tip sizes ...
herb johnson
the smaller the flow rate, the higher pressure do a better job of atomization , the higher the flow rate, the more pressure is needed to get better atomization, so the smaller pressure ratio pumps like 15-1 which is typical aa pressure pumps they can't do real high flow rates, hope that help you out
good luck
herb j
6/23/20       #3: Question about spray tip sizes ...
Generally it’s the density of fluid. The ratio of solids to solvents & reducers.
Thicker fluid needs a larger hole size.
The gun manufacturer give general starting sizes. Solvent clear, color or primer. Waterborne clear, color or primer.
The company that makes the product(MLC) gives specific setups for specific products. They do extensive testing.
Keep in mind it’s a starting point. The general method is to start with their setting. If it’s not working try adding 5-10% reducer. No luck go up a tip size and no reducer. If you’ve got some cheap gun or not enough air pressure then go up a size plus reduced.
There are numerous variables involved. Air, gun, product, surface, temperature/humidity, and your skill/experience.
6/27/20       #4: Question about spray tip sizes ...
They are spraying little 1'x1' samples. Those tips might work fine for that. You are probably spraying cabinets, doors and larger panels. Tiny tips will work if you want to take forever to spray something.
Smallest tip I use is a 06-114 which is .011" I use this for smaller items like normal size door. I usually run 35psi and 16psi air (trigger pulled)
I have a 09-134 but I rarely use it because it's my in between size but I use to use it for larger panels and doors.
I have a 12-174 tip which is what I use for cabinets and large panels. If I'm spraying MLC Stealth for doors I'll use this tip also. I run 40psi and 21psi (trigger pulled)
If I'm spraying Clawlock out of my 06-114 tip I'll push the pressure up to 40psi and the air to 19psi.
But it's also by sight, if you see tails you push the air up more. If you aren't getting the flow you want push up the pressure. But remember more fluid pressure might require more air pressure.
