No suction on sata AAA
7/9/20
Dan
I’ve lost suction on my sata AAA. And tips for a fix ?
7/9/20       #2: No suction on sata AAA ...
gralyn Member
check that the ball at the bottom of the pump is not stuck. Has it been a while since using the AAA?
7/10/20       #3: No suction on sata AAA ...
I have a Kremlin and when that happens the large ball at the bottom of the pump isn't seating properly. Usually something got stuck to it and it can't seat properly.
Usually a pretty easy fix. 10 minutes to take it apart, clean it and put it back together.
Not sure how it would be on your Sata pump.
7/13/20       #4: No suction on sata AAA ...
Shane
like other suggested... when a pump sits dry or not primed in cleaner or solvent the ball can stick to the cage....... or there is an obstruction of gook in the cage with the ball....... try to tap with a hammer while cycling the pump will cure them most of the time.... its not a big deal to take the bottom off and give the cage/ ball a scrub
    • 2Sand
