Scratches and cloudy spots
7/10/20
Michael Cox Member
Website: http://coxfinewoodworking.com
On my last coat of latex poly, I ended up with dust nits everywhere. I went through a rub out process with 400, 600 sandpaper, 00 & 0000 steel wool, 4F pumice& rottenstone. I finally got it to a spot I thought acceptable and it is glass smooth. However in the sunlight it now looks awful. There are scratches on the toner edge and cloudy wear through spots. I am in a quandary as to where to go from here. Strip and start over or sand with 350 and give a coat of satin poly.
7/10/20       #2: Scratches and cloudy spots ...
Pascal
Depending on the cost of adding another poly coat. I'd say you have Nothing to loose trying it.
If it works then good for you. Otherwise it's going to end up the same --> stripping.
I have sometime had good luck adding another coat of finish and was glad I did it since I avoided stripping. Sometime I ended up having to strip anyway. Adding another layer will not make the process much harder than it is already.
If another coat is just too much $$$ to risk it then strip. At least there is no unknown here
7/10/20       #3: Scratches and cloudy spots ...
If you used 00 steel wool after 600, that is where your scratches came from. Also 6 passes from different abrasives is no wonder you cut through the finish. Buy some Abralon sanding pads and just go through those grits till you get the sheen you want.
7/10/20       #4: Scratches and cloudy spots ...
Michael
I have abralon 180, 360,500 & 2000.
Is that what you had in mind?
I like the glass smooth feel of a run out but the aggravation on a cross grain veneer is not worth it.
Has the abralon worked well for you on dust nits?
7/10/20       #5: Scratches and cloudy spots ...
MarkB Member
You said you used water borne poly... if you actually used steel wool Id say your shot. Steel wool and waterborne no workie workie. Even with all the sanding and polishing my guess is you will have small particles of steel wool embedded in the finish and when you apply another they will look like someone sprinkled black pepper in your finish.
Maybe others have a better solution or think it wont be a problem but I have seen the steel wool and waterborne poly thing several times.
7/10/20       #6: Scratches and cloudy spots ...
Michael
You are correct. Synthetic steel wool is the key.
7/10/20       #7: Scratches and cloudy spots ...
MarkB Member
Ahh, whew.. good for you.
7/11/20       #8: Scratches and cloudy spots ...
00 = 360
0000 = 800
Latex is not the proper term. We use waterborne.
We use paper, scotchbrite, followed by graded buffing compounds. Depending on the manufacturer pumice is not consistent.
You need to have a good feel for the number of coats if you are buffing to prevent sand thru.
Another trick is to wet the surface with a solvent or water. That will help to determine if you can see the previous scratches. Do not use alcohol on wb coatings. It’s very aggressive.
Stripping sounds like a ton of work.
