Graco 395 ultra pro
7/12/20
Tadhg
Hi all I have small construction business based in nyc and for last 6 years I have been priming all my Millwork with oil base paint ; I have been using finish line gravity feed guns with good results and have used them for finish coats also but we have thin paint a lot for spraying. I have been looking at the Graco 395 ultra pro as it serves 2 purposes. First I can take it to different job sites second. It says it will spray direct from paint can has anyone any info on one of these thanks Tadhg
7/12/20       #2: Graco 395 ultra pro ...
duster
That model Graco will spray unthinned paint just fine on walls. To get good results on millwork, you will likely have to thin 5% - 10%. It will depend on the paint, tip size, ambient temperature and humidity. The only way to know is to do some tests.
7/13/20       #3: Graco 395 ultra pro ...
Shane
thats a decent little airless rig..... buy an assortment of tips... orfice diameter and pattern width... once you have a good range you will be able to taylor your rig to spray how you like..... mostly your going to need 17 thousandths to 21 thousandths tips with 4" wide tips for trim and 12-15" tips for others... good luck.. it's going to take some wins and fails to learn its habits.
7/13/20       #4: Graco 395 ultra pro ...
Tadhg
Thanks guys I’m bit surprised that I still have thin to paint trims. We roller all walls I’m purchasing this for Millwork /trim I think I’m using wrong gun in finish line I think there more suited to stain /lacquer. Not paint. Is there any gun specifically for paint Thanks for reply’s T
7/14/20       #5: Graco 395 ultra pro ...
We have a Grace 390. We use the 310 LP tip to spray topcoat on doors & trim.
We primarily spray the higher quality wb enamels. They are relatively thin to start with out of the can. Depending on the product or temp we might reduce 5% max with water to get it to layout.
Oil based should spray easier. Personally I stopped using oil based anything years ago because of slow dry times. You definitely need to use a faster reducer if spraying.
