spraying beaded face frames
8/30/20
John Bishop Member
Wondering if anyone else has had issues when spraying beaded face frames? I occasionally have Kitchen cabinet jobs featuring beaded frames and it seems to always be a bit of a challenge to get a full coating into the beaded groove, especially on the smaller bead/groove of around 1/8". I normally try and keep air pressure down a bit and hit from 2 angles but worry if I'm getting as good of a coating as I should. Any tricks out there?
8/30/20       #2: spraying beaded face frames ...
Pre-spraying the beads with an HVLP set at a point spray with a low output gets the color in there. Then you spray with you AAA as usual.
9/1/20       #3: spraying beaded face frames ...
Shane Welch
if we are talking color or dye stain then i would...reduce atomizing pressure... weaken the color mixture with solvent... slow my pass down and make more passes on the substrate...
9/1/20       #4: spraying beaded face frames ...
If you are talking stain rag it on.
9/1/20       #5: spraying beaded face frames ...
JeffA
I know this may sound goofy but in cases like this if its a spray product I will 'push' the coating in. That means you angle your gun into the direction you are spraying. That helps with Faraday effect. But nothing is perfect and it takes a little practice.
9/15/20       #6: spraying beaded face frames ...
John Bishop Member
To clarify, this is usually a pigmented finish , not stained. I have tried using a small detail gun but the finish is a bit too heavy viscosity to work in that gun. Maybe trying a small brush next.
