CV Thinning Tips
10/11/20
Dan Sadler Member
Hi Guys.
I've finally made the switch to conversion varnish and am wondering why it took me so long to do so.
I'm looking for some advice on thinning. The painter that turned me on top CV says he sprays seal and top coat full strength. I'm using Shermin Williams Water White CV, they recommend 15% thinning for seal coat and 5% for final coat.
I'm curious if guys adjust the percentages for different wood species, or over stain?
Any adjustments for temperature?
Any other CV tips to share?
Would appreciate any tips!
10/12/20       #4: CV Thinning Tips ...
You will need to give more information to get helpful advice. What is your spray equipment? What do you spray, how much?
I don't know how many people use viscosity cups but I do when I need to work out the reduction rate for finish. I try to keep in a viscosity range that I know works for my gun and technique. I have reliable repeatable results even though I go long periods without spraying.
10/12/20       #5: CV Thinning Tips ...
Shane Welch
I typically base my mixtures of Sherwin CV products based on what coating thickness I want to achieve.... open pore/closed pore look as well as the environmental conditions in the shop. I reduce sherwin C.V's with butyl acetate and retard with butyl cellosolve.... The rate depends on conditions at hand..... In some instances we reduce as much as 40% to achieve an open pore close to the wood finish. We use t67F6 & t67F7 vinyl sealers under everything instead of self sealing... dry times are better as well as sandability.
10/14/20       #6: CV Thinning Tips ...
Jim Clark  Member
I have found that auto grade urethane reducer works much better to thin CV with.
It was suggested to me by a paint chemist years ago and
I've been using it ever since.
10/18/20       #7: CV Thinning Tips ...
Dan Sadler Member
Thanks for the suggestions.
I'm spraying with a Titan ED655, diaphragm airless. I don't spray all that much as I'm not a full-time cabinetmaker. I've considered upgrading but honestly this setup gets pretty good results.
10/18/20       #8: CV Thinning Tips ...
Al
Dan,
I have that unit also. I used it once for cv and it came out really nice. I was always concerned when cleaning and leaving thinner in it. Do you leave thinner in pump and lines when storing it?
10/18/20       #9: CV Thinning Tips ...
Dan Sadler Member
Al,
Yes I leave lacquer thinner in the lines, although I've learned a few things the hard way.
Firstly I rinse the hopper pretty well so that the thinner I'm pushing through the lines is pretty clean. For storing I make sure the inlet valve is filled with thinner and I use the plug it came with so it doesn't evaporate. If allowed to evaporate then a residue may be left on the inlet valve parts.
After a project before putting the sprayer away I remove and disassemble the inlet and outlet valves and clean. This may be overkill but I like the peace of mind knowing that when I want to use the sprayer it's ready to go.
10/18/20       #10: CV Thinning Tips ...
Al
The time I used it for cv the residue did accumulate in the inlet so I was reluctant to use it for cv although it did spray really nice. I started using the unit for waterborne products only. The problem is run water through it and then they tell you to put a small amount of light duty oil in the inlet so to avoid rust. Now the next time I use it I need to rinse to get out oil. Basically cleaning it twice but with thinner sounds like it will just be once and done.
I bought mine at local SW store but I found a company called Gleem painting products online and the sell all the parts and hoses for the 655. I bought a 15’ hose from them so less wasted material on cleanup. I also purchased another hopper from them so I have one for pigmented and one for clear.
11/5/20       #11: CV Thinning Tips ...
Cosmo Member
I like the first coat on bare wood to really sink in. So I will thin 50% or more. I use the gloss for two or sometimes three coats. I might thin all the coats 50%, or less, I really don't have a set system. Sometimes I just have to sand once (320 grit) after the second coat. Other times I sand between every coat just quickly by hand. I always use the dull rub effect for the final coat. I like the SW water white CV as it seems to be very forgiving and never had a call back yet. I use a conventional spray system so what I do might not work with what you have. But I do notice if I spray it without thinning it enough, I have to spend more time sanding and the last coat might not lay down flat.
12/22/20       #12: CV Thinning Tips ...
Jim
Jim Clark
Do you also prefer the automotive reducer to butyl acetate ?? Have you compared them??
Love CV, just looking to improve...
Thanks Jim
