mountain cabinet finishing
10/30/20
scott
We live in southern calif. and have a job in our local mountains. Job has flat veneers and mdf painted surfaces. Finish we intend to use is ML Campbell CV products. I'm sure cabinets will be installed before house is fully heated for winter time and air temp can be a 30 degree drop from our shop temp. Any issues that i should be aware of or plan for ahead of install. Finish will be fully cured before installation begins. Thanks for insights.
10/30/20       #2: mountain cabinet finishing ...
21 days above 68ºF for full cure for most MLC products
10/30/20       #3: mountain cabinet finishing ...
rich c
ML Campbells has 23 solvent based CV products alone. You'll have to narrow down what you plan to use for questions like that. Dry and fully cured are two very different things.
10/30/20       #4: mountain cabinet finishing ...
scott
Sorry, Krystal for wood finish, Stealth for the pigmented, Clawlock Primer, all 275 voc for southern calif.
