White oak stain
1/2/21
Ag Member
Hello all hope you all have a good year
I have a project that includes an entrydoor and interior doors
The customer want a modern look and he want to use white or redoak veneer
Can any one give me an advice about what type of stain to use to give it a modern look a little bit brownand any picture will be much appreciated
This is the door design a simple door with joints
Thank you in advance
View higher quality, full size image (722 X 1280)
1/2/21       #2: White oak stain ...
rich c
If you want oak doors to look modern, brown is your very last choice. To make it modern you should either bleach it for no color or paint it gray.
1/3/21       #3: White oak stain ...
Ag Member
Thank you for your reply
Do u have any picture
And grey oak should i paint it or stain and any picture will be much appreciated
1/3/21       #4: White oak stain ...
mastercabman Member
As mentioned
Keep it natural, maybe use a waterborne so that it is as clear as possible
Or I have seen/installed white oak with this graphite like stain
It's a little dark but if doing flat slab panels
It is very modern
View higher quality, full size image (3072 X 4096)
1/3/21       #5: White oak stain ...
rich c
I can't help you any more because "modern" means many things. Mid Century Modern, Danish Modern, and even Contemporary.
1/5/21       #6: White oak stain ...
mauricio poli
You can check some ideas in pinterest.com
3/6/21       #7: White oak stain ...
Daniel Shafner Member
Seal with vinyl sealer.
Block sand with 150 grit and then 180 grit.
Wipe on/off Minwax ebony stain.
Topcoat.
    • 2Sand
