making spray stain
1/4/21
nicko
Can i make a spray no wipe stain out of ML Campbell wiping stain and their clear stain base and thinner. What would be best to use as a thinner. I want to spray some hard maple and try to avoid some blotching. I have mixed some dye stains with DNA but can not seem to get the color i want.
1/5/21       #3: making spray stain ...
mauricio poli
I use PU thinner with dye stains , applying a wet coat. If you need white, use 844 white pigment. You have to put a mixer inside your bucket to mix the with pigment during the application time. It is important to sand with 180 final.
1/5/21       #4: making spray stain ...
rich c
Traditionally, stain is a combination of course pigment and dye. The wiping part deposits the course pigment into the pores of the wood and dye colors the dense cells. Getting the color right is just that, adjusting the dye colors. If you want depth, it usually is a two part process of wiping the stain and adding color on top. The color can be added as a toner when it's mixed in a clear finish layer, or a layer of dye before the first clear coat. Adding a dye to a clear stain base is not what you want to do. Add it to a clear that is compatible to the clear you use for a top coat. Getting a perfect color match across all the parts in the booth requires some skill with the gun to keep the same overlap and speed.
1/6/21       #5: making spray stain ...
I agree with others, I would get a toner and spray that on first and then apply the stain, wiping stain will work fine over the toner.
After this you apply your topcoats of clear.
You can also tint your clear like Rich mentioned.
The important thing is you want to keep track of all your mixtures and your processes perfectly so if you have to replace a damaged piece or if the customer adds something later it will be easy to match.
1/9/21       #6: making spray stain ...
Nick
Behlen stain/dye. Thin with dna. spray with a
quality gravity gun with a 1.0. Spray multiple coats until you achieve your desired color intensity. Either make a mental note of how you achieved your desired color or write it down and repeat on all your pieces. Not hard but not for the beginner.
