Black Conversion Varnish
1/8/21
scott
Spraying Black Conversion Varnish on Flat Premium MDF, I plan 2 coats of black Clawlock and 2 coats Black CV satin. Anything to watch out for with a dark painted finish? Thanks
1/8/21       #2: Black Conversion Varnish ...
Scott Gibson Member
Website: momentumwoodworks.com
We are doing the exact same thing at the moment. Make sure you get two really good coats of the clawlock down. If you don't, you'll know it when spraying the CV. Which product are you using for your CV?
1/8/21       #3: Black Conversion Varnish ...
scott
Hi Scott, we are using ML Campbell Krystal 275 voc. in Black. I"ll know this weekend.
1/8/21       #4: Black Conversion Varnish ...
For black I shoot 2 coats of black Clawlock and then 2 coats of clear Krystal.
1/9/21       #5: Black Conversion Varnish ...
Scott Gibson Member
On a similar note..what do you guys use for spraying other dark colors for conversion varnish? We've used both ML Turino and ML Stealth but in the dark colors that need to be mixed in a clear base...it takes a long time to dry....especially, in the winter.
1/9/21       #6: Black Conversion Varnish ...
scott
Leo, I had been told to do it your way but my only reluctance is a sand thru that get missed and clear coat shot over it. any problems like this?
1/9/21       #7: Black Conversion Varnish ...
Jim Clark
When I want a dark color I use Sherwin Williams conversion varnish.
It's pretty thick and needs extra reduction.
1/9/21       #8: Black Conversion Varnish ...
Black Mohawk marker on sand throughs which is usually a corner so it's easy to hide.
3/6/21       #9: Black Conversion Varnish ...
Daniel Shafner Member
Black conversion varnish:
Black Turino is a nightmare. Sorry to MLC, but their clear base sux eggs through a straw with it's five day stack time.
Resistant in black is fine. Reduce it with the C1621 Care Reducer.
Stealth in black will also work. The only reducer slated for Stealth is the C1621 Care Reducer. Look to add in 25% or more.
Most distributors only have lamp black for black colorant. If you can, ask for jet black or carbon black. Lamp black is gray compared to those blacker blacks. For example, Steinway pianos do NOT use lamp black.
