2k poly toner
1/11/21
Kris Member
Hey all,
I've mostly been spraying conversion varnishes or waterborne, but have a job coming up that requires 2k poly.
On stain jobs, I will often mix in a bit of stain (wb or solvent depending on the finish) with my clear as a toner coat to even things out on maple, etc.
I'm wondering if that is a possibility with 2k poly, or if I will run into trouble.
lf not stains, could I use dyes? pigments? tints?
Should I shoot a toner mixed into a sealer of some sort?
I have sprayed 2k poly before, but only as a clear, or painted, never over a stain.
Any advice in this area would be great.
Thanks so much
Kris.
1/12/21       #2: 2k poly toner ...
Bob Niemeyer  Member
Kris, your 2k urethane supplier will have suggestions what to mix to make a toner. I Spray tons of ICA 2k Urethane and make a shader/toner all the time.
Do not use alcohol based dyes. or oil stains in your 2k urethanes. All the manufacturers of 2k urethanes have the products to make your toners, give them a call.
1/14/21       #3: 2k poly toner ...
Kris Member
Thanks Bob
Sounds like the reasonable thing to do for sure.
3/7/21       #4: 2k poly toner ...
Steven Hayes Member
Kris:
Autobody supply shops sell a product called intercoat clear, which is very thin and designed for mixing custom tints, candies, etc. that get applied under the 2K topcoats. You can mix analine dyes (i.e. Transtint) with this to make toners of any color. Guitar companies have been using this technique. Tamco paint makes an HC-895 intercoat clear that is pretty reasonable, and they offer good support.
