Kremlin waterborne cleanout
1/12/21
Eric Member
I am considering a Kremlin AAA. I've searched but not found a clear step by step rundown of how to clean the system between use with waterborne.
As a 1 man shop I'm concerned whether it is practical for occasional use or if cleaning is to much time/hassle. If you are spraying 2 - 3 times a day on a project, do you clean between? My experience with waterborne spray gun cleaning tells me just rinsing with water leaves a film without brushing, how does that work with hoses etc.? The attraction is a better finish and especially less overspray which I've found the bane of waterborne.
1/12/21       #2: Kremlin waterborne cleanout ...
david zaret Member
it's not bad. between coats, pump out the finish back into the pail, and then i run warm soapy water through, and then warm clear water through. that works between coats quite well. chemicals are helpful for long-term storage, but it's only a few minutes to recapture the finish in the hose and pump, and then clear it out well enough to sit until the next coat.
which waterborne are you spraying?
1/13/21       #3: Kremlin waterborne cleanout ...
Eric Member
Thank You for the reply David . What about the gun, cap, and tip? Is just flushing as described enough? No disassembly? How long could it sit without a more thorough cleaning?
I have tried numerous brands of waterborne, have battled with grain raise (on Medex) and "sandpaper texture" from overspray with all. Had settled on Agualente as working best for me then stared having problems with the primer that had previously worked fine. My supplier recommended Sirca, I've only sprayed a gallon of top coat (on Agulente primer) but it seems far superior and I'm excited it may finally solve some of my issues with waterborne.
1/13/21       #4: Kremlin waterborne cleanout ...
Kevin B
Get some acrastrip for cleaning, If i'm shooting 1-2 times per day I just leave the product in the gun and lines, ive even done it for a day or two. If its not catalysed mix then no big deal and less waste. I take the air cap off with the tip and drop it in some thinner, if its going to be awhile ill put a piece of tape over the seat or set just the gun nose in a shallow cup of thinner till my next spray.
