SW Pre Cat Lacquer
2/7/21
raj
I did a full kitchen for a customer using SW pre cat lacquer that was tinted to the color they wanted. They were pretty rough a a few doors that will need to be replaced. I have two unopened cans but they are 1 year old and SW suggests using them by 3 months after mixing. Now I know the strength of the finish will not be the same, but does anyone know how different it would be? If I need to get more I have to buy a minimum of 5 gallons which gets pricey, naturally they have to pick up the cost. So for a few doors get a new batch or is it ok to use what I have? Thanks much.
2/7/21       #2: SW Pre Cat Lacquer ...
Gabe Member
I was told by sherwin with some old cat laq it may not cure properly(stay soft). You could try mixing it well and doing a sample piece. Probably not worth the risk on a customer’s project though.
2/8/21       #3: SW Pre Cat Lacquer ...
The catalyst is used up. Don't use it unless you like trouble. Have them mix the color up again in a new batch.
2/16/21       #4: SW Pre Cat Lacquer ...
I know they all say that you can't use it when its after a year or so, but I don't know I've used old pre cat before and haven't had issues, I have never used sherwin Williams products so maybe its different, I actually just used some magna lac that by the can is at least 20 years old and it worked perfectly fine, it was a project for my daughter but there were no issues at all and it is as hard as it would be
2/22/21       #5: SW Pre Cat Lacquer ...
Joel
Your local SW is being douchy not wanting to sell you 1 gallon only. Kick them to the curb and use MLC campbell. Same thing anyway in pre-cat.
2/27/21       #6: SW Pre Cat Lacquer ...
Chris Payne
What you mean have to buy 5 gallons I have them mix me 1 gallon cans all the time.
